Introduzione
This replacement guide will cover how to remove the inner fan of the Samsung ATIV Book 9 Plus.
Parti
Nessuna parte richiesta.
  1. Remove the ten 4.3mm Phillips #00 screws from the bottom cover of the laptop.
    • Remove the ten 4.3mm Phillips #00 screws from the bottom cover of the laptop.
  2. Press the button to release the bottom cover.
    • Press the button to release the bottom cover.
    • Remove the five 4.3mm Phillips #00 screws from the battery.
    • Lift the battery with both hands and remove.
    • Remove the four 4mm Phillips #00 screws from the fans.
    • Disconnect the fans from the motherboard.
    • Remove the fans.
Conclusione
Sean Kim
Membro da: 12/04/2018
616 Reputazione
4 Guide realizzate
UW Tacoma, Team S1-G2, Liner Spring 2018 Membro di UW Tacoma, Team S1-G2, Liner Spring 2018
UWT-LINER-S18S1G2
5 Membri
4 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 140
