Salta al contenuto principale
Samsung ATIV Book 9 Plus Keys Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: passo 1, immagine 1 di 2 Samsung ATIV Book 9 Plus Keys Replacement, Keys: passo 1, immagine 2 di 2
    • Open your laptop so your keyboard is facing you and is easily accessible.
  2. Samsung ATIV Book 9 Plus Keys Replacement: passo 2, immagine 1 di 3 Samsung ATIV Book 9 Plus Keys Replacement: passo 2, immagine 2 di 3 Samsung ATIV Book 9 Plus Keys Replacement: passo 2, immagine 3 di 3
    • Using a plastic opening tool, carefully push the thin tip under the key.
  3. Samsung ATIV Book 9 Plus Keys Replacement: passo 3, immagine 1 di 2 Samsung ATIV Book 9 Plus Keys Replacement: passo 3, immagine 2 di 2
    • Pivot the tool upwards. This should pry the key away from the keyboard.
    • Hearing some snapping sounds should be normal as the key lifts away from its attachments.
    • Continue lifting the tool until the key comes away completely or gently pull the key off. Repeat for other keys as needed.
    • Be gentle, as the attachments may accidentally break with rough handling.
Conclusione
Altre 3 persone hanno completato questa guida.
unknown
Membro da: 03/20/15
261 Reputazione
1 Guida realizzata
Baylor, Team 2-3, Grigsby Spring 2015 Membro di Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 6,129
