Salta al contenuto principale
Samsung ATIV Book 9 Plus Internal Fans Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Internal Fans Replacement: passo 2, immagine 1 di 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: passo 3, immagine 1 di 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: passo 3, immagine 2 di 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: passo 3, immagine 3 di 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Internal Fans Replacement: passo 4, immagine 1 di 2 Samsung ATIV Book 9 Plus Internal Fans Replacement: passo 4, immagine 2 di 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Internal Fans Replacement: passo 5, immagine 1 di 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
Conclusione
Altre 2 persone hanno completato questa guida.
Rhannie Surel
Membro da: 03/20/15
137 Reputazione
1 Guida realizzata
Baylor, Team 2-3, Grigsby Spring 2015 Membro di Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Membri
4 Guide realizzate
Un commento
I think that's to easy!
Ocean - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 4,460
