Salta al contenuto principale
Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 2, immagine 1 di 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: passo 3, immagine 1 di 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: passo 3, immagine 2 di 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: passo 3, immagine 3 di 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 4, immagine 1 di 2 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 4, immagine 2 di 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 5, immagine 1 di 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: passo 6, immagine 1 di 1
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 7, immagine 1 di 1
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: passo 8, immagine 1 di 1
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
Conclusione
Ryan Smith
Membro da: 04/01/19
193 Reputazione
2 Guide realizzate
IUPUI, Team S7-G7, Wilson Spring 2019 Membro di IUPUI, Team S7-G7, Wilson Spring 2019
IUPUI-WILSON-S19S7G7
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 647
