Salta al contenuto principale
Samsung ATIV Book 9 Plus Charger Port Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: passo 2, immagine 1 di 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: passo 3, immagine 1 di 2 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: passo 3, immagine 2 di 2
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: passo 4, immagine 1 di 1
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: passo 5, immagine 1 di 1
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: passo 6, immagine 1 di 1
    • Remove the disconnected charger port.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team S6-G6, Baechle Fall 2017 Membro di IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,907
