Salta al contenuto principale
Samsung ATIV Book 9 Plus Battery Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Battery Replacement: passo 2, immagine 1 di 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, immagine 1 di 3 Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, immagine 2 di 3 Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Unscrew the four 4.55 mm Phillips #000 screws on the edges of the battery.
  4. Samsung ATIV Book 9 Plus Battery Replacement: passo 4, immagine 1 di 2 Samsung ATIV Book 9 Plus Battery Replacement: passo 4, immagine 2 di 2
    • Lift to remove the battery from the laptop.
    • Place in the new battery to match the edges located on the laptop. Push on the top edge of the battery to secure it in place.
Conclusione
Altre 7 persone hanno completato questa guida.
Nidhi Patel
Membro da: 03/20/15
271 Reputazione
1 Guida realizzata
Baylor, Team 2-3, Grigsby Spring 2015 Membro di Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Membri
4 Guide realizzate
4 Commenti
Could you point to the RAM modules in the pictures please
rerof - Replica
http://www.myfixguide.com/manual/samsung...
There are no RAM modules. They are welded in the mother board.
Best regards!
Raul Lacavex -
any updated amazon product?
amitshalem - Replica
I just bought and installed this battery from Amazon: https://www.amazon.com/gp/product/B07NW7...
Mark Wolfman -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 12,625
