Salta al contenuto principale
Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement, SSD: passo 1, immagine 1 di 1
    • Remove ten Phillips #00 screws from the back panel.
    • Remove the back panel.
  2. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: passo 2, immagine 1 di 1
    • Unscrew the five Phillips #00 screws which connect the battery to the frame of the laptop.
    • Lift the battery from the bottom edge, taking care as it is disconnected from the motherboard.
    • During reassembly, insert the top edge of the battery first, aligning the pins of the battery with the pins of the motherboard connection.
  3. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: passo 3, immagine 1 di 1
    • Remove the interconnect ribbon cable labeled “main” and “sub” by prying the pin connections up with a spudger or plastic opening tool.
  4. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: passo 4, immagine 1 di 1
    • Remove the single screw holding down the SSD with a Phillips #00 screwdriver.
    • Remove the SSD from its slot located to the right, just above the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 822
