Salta al contenuto principale
Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement, Fan Assembly: passo 1, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the 10 screws holding the back panel together.
    • Remove the back panel.
  2. Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement: passo 2, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the 4 total screws (2 per each fan).
    • Disconnect the cable connections linking each fan to the motherboard with a spudger.
    • Remove each fan.
Conclusione
To reassemble your device, follow these instructions in reverse order or follow steps 4 to reassemble your laptop.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 381
