Salta al contenuto principale
Samsung ATIV Book 9 Lite Battery Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: passo 1, immagine 1 di 2 Samsung ATIV Book 9 Lite Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: passo 2, immagine 1 di 3 Samsung ATIV Book 9 Lite Battery Replacement: passo 2, immagine 2 di 3 Samsung ATIV Book 9 Lite Battery Replacement: passo 2, immagine 3 di 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: passo 3, immagine 1 di 3 Samsung ATIV Book 9 Lite Battery Replacement: passo 3, immagine 2 di 3 Samsung ATIV Book 9 Lite Battery Replacement: passo 3, immagine 3 di 3
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: passo 4, immagine 1 di 2 Samsung ATIV Book 9 Lite Battery Replacement: passo 4, immagine 2 di 2
    • Using your hands remove the battery from the computer.
Conclusione
Altre 3 persone hanno completato questa guida.
Phat Tran
Membro da: 09/16/18
786 Reputazione
5 Guide realizzate
2 Commenti
please where can i get the battery 🔋
Bethel Ugwudike - Replica
Please where can i get the battery for Samsung 930x5j910s5j940x5j
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,675
