Salta al contenuto principale
Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement
Cosa ti serve
  1. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Backplate: passo 1, immagine 1 di 2 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Backplate: passo 1, immagine 2 di 2
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: passo 2, immagine 1 di 1
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, USB Ports: passo 5, immagine 1 di 2 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement, USB Ports: passo 5, immagine 2 di 2
    • Disconnect the ribbon connecting the motherboard with the USB ports .
    • Disconnect the speaker from the board
  6. Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: passo 6, immagine 1 di 2 Samsung ATIV Book 7 NP740U3E-K01UB USB Ports Replacement: passo 6, immagine 2 di 2
    • Unscrew the 5mm screws with the Phillips #0 screw driver.
    • Lift the board out of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 265
