Salta al contenuto principale
Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement
Cosa ti serve
  1. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Backplate: passo 1, immagine 1 di 2 Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Backplate: passo 1, immagine 2 di 2
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: passo 2, immagine 1 di 1
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Track Pad: passo 5, immagine 1 di 1
    • Disconnect the track pad from the motherboard.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: passo 6, immagine 1 di 2 Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: passo 6, immagine 2 di 2
    • Peel the tape on the track pad back.
    • Unscrew the five 2mm screws with the Phillips #0 screwdriver.
    • Rotate the track pad out of the case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 228
