Salta al contenuto principale
Samsung ATIV Book 4 Screen Replacement
Cosa ti serve
  1. Samsung ATIV Book 4 Screen Replacement, Screen: passo 1, immagine 1 di 2 Samsung ATIV Book 4 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Be sure the computer is off, and open the computer so that the screen is showing.
    • Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
  2. Samsung ATIV Book 4 Screen Replacement: passo 2, immagine 1 di 1
    • Remove the four 3.5mm screws securing the screen.
    • Tilt the screen back before removing the screws, there is a possibility it could fall and damage your keyboard or the ribbon cable connected to it.
  3. Samsung ATIV Book 4 Screen Replacement: passo 3, immagine 1 di 1
    • Place the screen gently on the keyboard.
  4. Samsung ATIV Book 4 Screen Replacement: passo 4, immagine 1 di 1
    • Remove the ribbon cable from the screen.
    • Remove and replace the screen.
Conclusione
Daniel
Membro da: 03/19/15
342 Reputazione
3 Guide realizzate
Un commento
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
RMS015 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,336
