Salta al contenuto principale
Samsung ATIV Book 4 Battery Replacement
Cosa ti serve
  1. Samsung ATIV Book 4 Battery Replacement, Battery: passo 1, immagine 1 di 2 Samsung ATIV Book 4 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Place the computer upside down.
    • Remove 2 rubber pads, by prying up on them.
    • There may be adhesive holding them down. If this is the case, the plastic opening tool may be needed to remove them.
    • Remove the seven 6.5mm screws on exterior of computer.
  2. Samsung ATIV Book 4 Battery Replacement: passo 2, immagine 1 di 2 Samsung ATIV Book 4 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the panel by sliding it down and lifting it away from the computer.
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Battery Replacement: passo 3, immagine 1 di 2 Samsung ATIV Book 4 Battery Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer, once all tabs are broken free.
  4. Samsung ATIV Book 4 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the four 3.5mm screws holding the battery.
    • Peel back the tape securing the wires to the battery.
    • Lift and remove the battery from its location.
    • Don't pull/tear the wires connected to battery harness.
  5. Samsung ATIV Book 4 Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery harness from computer.
    • Completely remove the battery and replace it.
  6. Samsung ATIV Book 4 Battery Replacement: passo 6, immagine 1 di 1
    • Plug battery harness back in.
    • Assure the wires are pointed up (towards you) then plugging back in, as shown.
Conclusione
Altre 4 persone hanno completato questa guida.
Chad
Membro da: 03/17/15
437 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 9,685
