Introduzione
If your laptop does not hold a charge or doesn't turn on unless it is plugged into its charger, the battery may have went bad. To keep your laptop running optimal and maintain a high charge duration, a battery replacement may be necessary.
Cosa ti serve
Place the computer upside down.
Remove 2 rubber pads, by prying up on them.
Remove the seven 6.5mm screws on exterior of computer.
Altre 4 persone hanno completato questa guida.
