Introduzione
When the body on the steam valve is cracked, it has to be replaced. This will show how to do that.
Cosa ti serve
Remove all attachments such as drawers, water tank, brewing unit.
Carefully pull the steam button out. If it is too tight, first loosen the cover (steps 2 to 4), lift slightly and then push the ratchet nose with a small screwdriver.
Remove the single T10 Torx screw on the rear edge of the top cover under the water reservoir.
Remove the single Phillipps screw on the rear edge of the top cover under the container of the coffee beans.
There are two Phillipps screws on the frontal unterside edge of the top cover. Turn them out.
The steam valve is located on the top right of the machine. If it has cracks, water will drip out of the valve body.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
