Salta al contenuto principale
Saeco Royal thermoblock removal
Cosa ti serve
  1. Saeco Royal thermoblock removal, Preparing: passo 1, immagine 1 di 1
    • Unplug!
    • Remove all attachments like water tank, brewing unit etc.
    • The pictures show a Royal Cappucino One Touch HD8930, but the opening procedure is similar to all models.
  2. Saeco Royal thermoblock removal, Top: passo 2, immagine 1 di 2 Saeco Royal thermoblock removal, Top: passo 2, immagine 2 di 2
    • The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
    • There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
    • The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
  3. Saeco Royal thermoblock removal, Rear side: passo 3, immagine 1 di 1
    • There are two screws to be turned out.
  4. Saeco Royal thermoblock removal, Front: passo 4, immagine 1 di 3 Saeco Royal thermoblock removal, Front: passo 4, immagine 2 di 3 Saeco Royal thermoblock removal, Front: passo 4, immagine 3 di 3
    • The screws are situated on the underneath of the cover. This type is held by four screws.
  5. Saeco Royal thermoblock removal, Lift cover off: passo 5, immagine 1 di 2 Saeco Royal thermoblock removal, Lift cover off: passo 5, immagine 2 di 2
    • Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
    • Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
    • The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
    • Most repairs can be done with the cover being laid up partially , it must not be completely removed.
  6. Saeco Royal thermoblock removal, Remove thermoblock: passo 6, immagine 1 di 1
    • This is what the removed thermoblock looks like. This one was 14 years old and leaking in various places.
  7. Saeco Royal thermoblock removal: passo 7, immagine 1 di 2 Saeco Royal thermoblock removal: passo 7, immagine 2 di 2
    • A look into the open device. The thermoblock is hidden under a pile of cables and tubes.
  8. Saeco Royal thermoblock removal: passo 8, immagine 1 di 1
    • It's safer to number the cable connectors on the electronics. You probably just need to disconnect the slightly hidden # 14 connector on the two green cables at the very bottom and # 7 on the blue cable on the top.
  9. Saeco Royal thermoblock removal: passo 9, immagine 1 di 1
    • The thermoblock is attached to the wall behind the brew group with only two Phillips screws.
    • Remove the two Phillips screws circled in red.
  10. Saeco Royal thermoblock removal: passo 10, immagine 1 di 1
    • Take out the thermoblock and place it on the machine.
    • Hold on! The thermoblock is still connected to the machine by many cables and hoses. Don't attempt to completely remove it just yet!
  11. Saeco Royal thermoblock removal: passo 11, immagine 1 di 2 Saeco Royal thermoblock removal: passo 11, immagine 2 di 2
    • Pull the clamp on the hose to the steam valve off.
    • Pull the hose circled in orange out.
    • There are two seals at the end of the hose that stick to the hose. Exchange them during re-assembly.
  12. Saeco Royal thermoblock removal: passo 12, immagine 1 di 1
    • Remove the metal holder of the thermal fuse.
    • My thermal fuse holder is heavily rusted, this may or may not be the case for you.
  13. Saeco Royal thermoblock removal: passo 13, immagine 1 di 1
    • Pull first the clamp, and then the second pressure hose out of the thermoblock.
    • There are two seals at the end of the hose. They stay stuck either at the end of the hose or afterwards, so don't try to remove them. Exchange them during re-assembly.
  14. Saeco Royal thermoblock removal: passo 14, immagine 1 di 2 Saeco Royal thermoblock removal: passo 14, immagine 2 di 2
    • Disconnect the connector with the two gray cables from the thermal switch.
  15. Saeco Royal thermoblock removal: passo 15, immagine 1 di 1
    • The blue cable from the thermoblock leads to the connector on the electronics, which is marked with 7 here. This particular plug stuck a lot, so force was required to pull it out.
  16. Saeco Royal thermoblock removal: passo 16, immagine 1 di 3 Saeco Royal thermoblock removal: passo 16, immagine 2 di 3 Saeco Royal thermoblock removal: passo 16, immagine 3 di 3
    • The Allen screw, which holds the holder of the two thermocouples, was not easy to open...
    • This can also be a Phillips screw. It may vary which appears for you.
    • Therefore, the plug on the electronics with the two green cables was pulled out. The plug has the mark 14 and is at the very bottom of the electronics.
    • Disconnect the plug with the yellow-green grounding wire from the support valve.
  17. Saeco Royal thermoblock removal: passo 17, immagine 1 di 1
    • Thread the green and blue cables out.
    • The thermoblock is free. Lift it out of the machine.
    • To replace the thermoblock, the attached components must be removed from the old block and transferred to the new part.
Conclusione
Repeat the steps in reverse order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
VauWeh
Membro da: 10/19/15
172.756 Reputazione
219 Guide realizzate
Repair is War on Entropy Membro di Repair is War on Entropy
Community
11 Membri
773 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,055
