Introduzione
The support valve is heavily used, as it docks with each cup of coffee inlet pipe of the brewing group. During a revision, you can replace the seals and inspect or replace the internal components. You have to open the machine and remove the thermoblock. There are units from the Royal series in which the support valve is not mounted to the thermoblock. On those it is sufficient to replace only the valve.
Strumenti
Ricambi
Nessuna parte specificata.
The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
The screws are situated on the underneath of the cover. This type is held by four screws.
Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
Most repairs can be done with the cover being laid up partially , it must not be completely removed.
This is what the removed thermoblock looks like. This one was 14 years old and leaking in various places.
The Allen screw, which holds the holder of the two thermocouples, was not easy to open...
Therefore, the plug on the electronics with the two green cables was pulled out. The plug has the mark 14 and is at the very bottom of the electronics.
Disconnect the plug with the yellow-green grounding wire from the support valve.
Remove the four Phillips screws securing the support valve.
Lift the unit with the support valve out of the thermoblock
Unscrew the valve out of the unit with a 13mm open end wrench.
Check if everything moves smoothly. Clean all parts well. Careful, they are sensitive.
The valve spring
The valve stamp. Check if the gasket on the valve seat is still good. Change it if necessary.
The sliding piece
Support seal on the thermoblock. Medium size.
Support gasket top. The largest of the three.
Support gasket bottom. The smallest.
Repeat the steps in reverse order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
