Introduzione
The pressure relief valve of this machine can get stuck and no longer be properly working. It is also possible for the valve seal to be damaged. Here's how you can revise or replace the valve.
Cosa ti serve
The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
The screws are situated on the underneath of the cover. This type is held by four screws.
Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
Most repairs can be done with the cover being laid up partially , it must not be completely removed.
This is what the removed thermoblock looks like. This one was 14 years old and leaking in various places.
The Allen screw, which holds the holder of the two thermocouples, was not easy to open...
Therefore, the plug on the electronics with the two green cables was pulled out. The plug has the mark 14 and is at the very bottom of the electronics.
Disconnect the plug with the yellow-green grounding wire from the support valve.
Here the pump viewed from above, a Ulka EX5 with 230V. The pump is stored in rubber pieces.
Pull the silicone hose off the rear elbow.
If not already done, remove the clamp on the pressure hose on the pressure relief valve. Then remove the pressure hose.
Unscrew the pressure relief valve with two wrenches SW 10 and 13.
Only the pump itself as well as the relief valve will remain.
If you want to replace the pump, you'll have to transfer the pressure relief valve to the new pump. You should also service your valve while you're at it.
The pressure relief valve can be opened with a 10mm open-end wrench. The screws can be very tight.
Check if the piston is stuck. If it is it will be necessary to free it.
Look at the seal: is there a deep circular groove pressed into it? If so, then it is possible that it does not close properly anymore.
The whole valve can be replaced with a new one.
It is also possible to gently pry out the seal with a needle and then turn it over. The back of the seal will seal properly if it is flat and smooth. Picture two and three show the front and back.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
