Salta al contenuto principale
Saab 9-3 Ignition Switch Module (ISM) Replacement
Cosa ti serve
  1. Saab 9-3 Ignition Switch Module (ISM) Replacement, The starting point: passo 1, immagine 1 di 1
    • Our starting point: The center console with the ignition switch in the middle
  2. Saab 9-3 Ignition Switch Module (ISM) Replacement, The tool: passo 2, immagine 1 di 1
    • This is the screwdriver bit used to remove all the screws.
  3. Saab 9-3 Ignition Switch Module (ISM) Replacement, The ISM (Ignition Switch Module): passo 3, immagine 1 di 1
    • This is the item we need to replace
  4. Saab 9-3 Ignition Switch Module (ISM) Replacement, Front side panels: passo 4, immagine 1 di 1
    • Step one is to remove the front side panels. There is a single (covered) screw in the footwell on each side that can be removed, and the panel slides rearwards, down and out.
  5. Saab 9-3 Ignition Switch Module (ISM) Replacement, Panel screw: passo 5, immagine 1 di 1
    • Unscrew and remove this screw
  6. Saab 9-3 Ignition Switch Module (ISM) Replacement, Front side panel comes off: passo 6, immagine 1 di 1
    • The panel can now come off.
  7. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rear cover: passo 7, immagine 1 di 1
    • Rear cover is removed next.
  8. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove rear panel: passo 8, immagine 1 di 1
    • Next, locate the rear cover visible from the back seats, between the two front seats. Pull it sharply to the rear, and remove.
  9. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rear side panels: passo 9, immagine 1 di 1
    • The rear side panels in front of the rear cover are now easily accessible and can be removed.
  10. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rubber mat in front of gear lever: passo 10, immagine 1 di 1
    • Next, remove the rubber mat in front of the gear lever.
  11. Saab 9-3 Ignition Switch Module (ISM) Replacement, Gear lever surround trim: passo 11, immagine 1 di 1
    • The (shiny) gear lever surround trim can now be prized off, starting at the rear, and removed.
  12. Saab 9-3 Ignition Switch Module (ISM) Replacement, Retaining frame holding screw: passo 12, immagine 1 di 1
    • Removing the gear lever surround trim exposes a single screw holding a retaining frame underneath the gear change mechanism.
  13. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 13, immagine 1 di 1
    • Unscrew the retaining screw
  14. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 14, immagine 1 di 1
    • Remove the retaining frame
  15. Saab 9-3 Ignition Switch Module (ISM) Replacement, Hand brake cover: passo 15, immagine 1 di 1
    • Slide out horizontally the protective plastic cover underneath the hand brake.
  16. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 16, immagine 1 di 1
    • This exposes a single screw. Remove this.
  17. Saab 9-3 Ignition Switch Module (ISM) Replacement, CD holder: passo 17, immagine 1 di 1
    • On the other side, remove the CD holder top cover,
  18. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 18, immagine 1 di 1
    • unscrew the two screws inside,
  19. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 19, immagine 1 di 1
    • and remove the CD holder itself. This exposes another single screw. Remove this.
  20. Saab 9-3 Ignition Switch Module (ISM) Replacement, Storage unit: passo 20, immagine 1 di 1
    • Remove the bottom rubber cover in the centre console storage unit.
  21. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 21, immagine 1 di 1
    • This exposes two screws that need removing.
  22. Saab 9-3 Ignition Switch Module (ISM) Replacement, Drinks holder: passo 22, immagine 1 di 1
    • The drinks holder has another rubber mat.
  23. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 23, immagine 1 di 1
    • There are no screws underneath, but this is a good opportunity to remove it and clean it separately.
  24. Saab 9-3 Ignition Switch Module (ISM) Replacement, Air duct: passo 24, immagine 1 di 1
    • Underneath the air vent controlling air flow to the passengers from the center console sits a square duct.
  25. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 25, immagine 1 di 1
    • The Haynes manual suggests pulling this out next, and although it is possible to do so, it requires force, and is much easier to do later when all other fixings have been removed.
  26. Saab 9-3 Ignition Switch Module (ISM) Replacement, Cable bundles: passo 26, immagine 1 di 1
    • There are two cable bundles connected to the center console from the rest of the car. One is connected via a large, square plug with a red tab.
  27. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 27, immagine 1 di 1
    • Push a screwdriver inside the red tab and pull, and the connector splits neatly apart.
  28. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 28, immagine 1 di 1
    • The other is an earth connector near the rear of the console. This can easily be pulled away.
  29. Saab 9-3 Ignition Switch Module (ISM) Replacement, Retaining screws in front of the gear lever: passo 29, immagine 1 di 1
    • Remove two screws located in front of the gear lever.
  30. Saab 9-3 Ignition Switch Module (ISM) Replacement, Horizontal retainer screws -- a fiddle to get out!!: passo 30, immagine 1 di 1
    • The next bit is a bit fiddly to get to: There are two screws going horizontally, one underneath the handbrake,
  31. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 31, immagine 1 di 1
    • the other on the CD holder side. These need to be removed. There is limited workspace. Use a separate loose screwdriver bit, and a spanner to twist it.
  32. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: passo 32, immagine 1 di 3 Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: passo 32, immagine 2 di 3 Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: passo 32, immagine 3 di 3
    • The center console is now loose, and can be puller backwards and upwards, and removed from the car.
  33. Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: passo 33, immagine 1 di 3 Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: passo 33, immagine 2 di 3 Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: passo 33, immagine 3 di 3
    • Tip the centre console upside down and locate the ISM ignition switch.There are four spring clips holding it in place. Use a screwdriver to compress each clip in turn, whilst pushing the switch out of its socket.
  34. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 34, immagine 1 di 3 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 34, immagine 2 di 3 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 34, immagine 3 di 3
    • The switch is connected to a cable via a connector. Locate the torque lever and twist this to release the connector.
  35. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 35, immagine 1 di 2 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 35, immagine 2 di 2
    • You now have the ISM in your hand. Swap this with a replacement unit. Mine cost £126,00 new from eBay. Clip it in the same spot, and connect the cable again.
    • The rest of the procedure is doing the dismantling in reverse. However, this is the best order that I found (choosing the wrong order once or twice):
  36. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 37, immagine 1 di 1
    • The square air conditioning duct goes in first. The console goes in next. It is a bit awkward to riggle past all the lugs, screws, tabs and cables, but just persevere. Once in, fit all the screws holding it in place, including the awkward ones.
  37. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 38, immagine 1 di 3 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 38, immagine 2 di 3 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 38, immagine 3 di 3
    • Connect the two cables. The earth connector is push-on, and the square plug self-locks when the red tab is pushed.
    • Next, fit the retaining frame underneath the gear lever, all screws around it, then the shiny gear lever surround trim, and finally the rubber mat in front of it. Fit the side rear panels, then the front panels (fasten them with the single screw), then the rear cover.
  38. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 40, immagine 1 di 1
    • With all side panels in place, re-fit the screws around the gear lever and CD holder. Finally, slide the handbrake cover in place, and screw the CD holder in. All rubber mats put in place (you *did* clean them whilst you had the chance, right..?). You are done!
    • Touch Wood, my car is now purring, with none of the issues I had before. Having heard quotes from around £1,000 upwards for a complete ISM / CIM refit, I am well pleased with the result.
Conclusione
Altre 15 persone hanno completato questa guida.
Lars Erlandsen
Membro da: 04/17/18
1.313 Reputazione
2 Guide realizzate
26Commenti sulla guida
And the key worked once plugged in and the battery is reconnected?
Michael Sullivan - Replica
These are great instructions. I had the dreaded ‘steering lock malfunction’ warning message on my 9-3. Bought an ISM off eBay for £35 and had it fitted and working fine in 2 hours. Thanks so much for posting.
Mike - Replica
Instructuctions spot on. In 1.5hrs I had the ISM out, cleaned and back in. And no more steering lock errors. !!!
gtsmail951 - Replica
Does anyone have advice on how to replace the ignition switch on a 1998 9.3 automatic transmission Saab
davina gammon - Replica
Most of these steps are not necessary at all, you can pull the ISM out from the side when you have removed the side panel, its tight but more than possible. This is very easy, 3h is a joke it takes 30 minutes at most!
Filip Andersson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 259
Tutti i Tempi: 36,190
