Introduzione
Here's a step-by-step tutorial to dismount each piece of the NAS until you reach the motherboard.
'Note: the interest of this tutorial is however limited.'
Indeed, most of the components that a user can be brought to add or change are now accessible directly, without disassembly (storage disks, memory expansion, SSD cache).
This is a step forward since, for example, a DS415 + / DS916 + must be completely removed to change a single RAM array.
Only the memory stack on the motherboard and fans remain inaccessible directly and require the disassembly of the NAS described in this tutorial to be changed (whether they are HS or replace them not the best).
The dismantling time is estimated at one hour (a single experiment on the timer). That said, it is certainly achievable in 20/30 minutes.
The photographs were taken with a CANON EOS 7D and an iPhone SE, using a portable LED studio.
Cosa ti serve
Here are the different interesting faces of the case: front (bay disks), rear (connectors and fans), below (2 hatches SSD).
2 RJ45 Gb ports.
Kensington security incision (K-lock)
2 M.2 NVMe 2280 ports (disk cache)
1 port for power supply
2 USB 3 ports (1 in front and 1 behind)
1 eSATA port
This is a significant innovation, the memory is now directly accessible and without disassembly of the housing, for the original bar as for the extension port.
Remove the 2 screws on the back of the case at the top and bottom (not the one above the USB port)
Slide the cover forward, then slide it out (here, to the left).
in red: SSD M.2 expansion card 2280
in yellow: USB port 3
in orange: internal connectors of the 2 fans
in green: 2 slots of RAM
in blue: SATA III backplane (4 hard drive bays)
in pink: fixing the fans on the chassis
Remove the 4 screws located on the blue electronic board.
You can remove the M.2 expansion board now.
Remove the screw from the holding plate of the USB connector 3.
Also remove the USB 3 connector screw on the rear side (this can be done later).
Remove the screws from the two shims to secure the disc cage and the two fans.
First 3 screws on SSD expansion board, on the bottom (bottom).
Then 2 screws on the upper face of the device (top).
Now that the screws have been removed, you can (after verification) remove the cage drives.
Remove the 8 screws from the fan grilles. They make it possible to maintain both the grilles and the fans.
According to the technical documentation of Y.S. TECH:
Voltage: 12 Vdc (7 to 13.2 range) for 100 mA (consumption)
Life time @ 40 ° C L10: 50000 h
Noise level: 23 dB
Max airflow: 36.3 cubic feet / minute
Rotation speed: 1900 rpm
Weight: 100 g
Remove the power cables from the fans, being careful to locate them (you never know) located on the motherboard.
Then remove the fans.
You will also be careful to unscrew the USB 3 connector fixing screw on the rear panel (if this has not been done previously).
Remove the 4 screws that secure the motherboard to the case.
Remove the motherboard from the case paying attention to the USB 3 connector on the front and the power button. To do this, move the front panel a little and lift the motherboard upwards (outside).
Once the motherboard is out, unscrew the 4 screws of the metal protective cover (metal plate).
Motherboard processor face
INTEL Celeron J3455 / 64-bit / Quad core 1.5 burst up to 2.3 GHz
Memory battery
Internal Beep
USB connector 3
Power button (power-on)
Flash memory with pre-loaded DSM 6.1 kernel to allow the NAS to boot before full installation of the OS
UEFI Insyde H2O BY56 chip ??
Memory side of the motherboard (pre-equipped with 4 GB of RAM)
NVMe M.2 SSD expansion card connector
Connector (PCIe ??) for SATA disk expansion card
Fan connector (x2)
Power connector
RJ45 LAN Connector (8P8C) x2
ESATA connector
Original 4GB DDR3L RAM Memory Stick 1866
To reassemble your device, follow the instructions in reverse order.
Be careful however, for the grilles of the fans it will be necessary to make sure to align the 2 small raised lugs on the back of the plastic grilles with the 2 small holes between the screws of the bottom of the fans!
Altre 36 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
15 Commenti
Un tutoriel complet, avec de bonnes photos, lecture claire et concise.
Bravo et merci pour ton travail.
merci pour ces encouragements !
