Salta al contenuto principale
SVP 5800 Front Casing Replacement
Cosa ti serve
  1. SVP 5800 Front Casing Replacement, Strap Hook: passo 1, immagine 1 di 3 SVP 5800 Front Casing Replacement, Strap Hook: passo 1, immagine 2 di 3 SVP 5800 Front Casing Replacement, Strap Hook: passo 1, immagine 3 di 3
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. SVP 5800 Front Casing Replacement, Front Casing: passo 2, immagine 1 di 2 SVP 5800 Front Casing Replacement, Front Casing: passo 2, immagine 2 di 2
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. SVP 5800 Front Casing Replacement: passo 3, immagine 1 di 2 SVP 5800 Front Casing Replacement: passo 3, immagine 2 di 2
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  4. SVP 5800 Front Casing Replacement: passo 4, immagine 1 di 2 SVP 5800 Front Casing Replacement: passo 4, immagine 2 di 2
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
Conclusione
Marist, Team 1-3, Laflen Spring 2016 Membro di Marist, Team 1-3, Laflen Spring 2016
MARS-LAFLEN-S16S1G3
2 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 355
