Salta al contenuto principale
SONY ZS-BTG900 Remote Motherboard Replacement
Cosa ti serve
  1. SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: passo 1, immagine 1 di 2 SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: passo 1, immagine 2 di 2
    • Flip the remote and remove the backing.
  2. SONY ZS-BTG900 Remote Motherboard Replacement: passo 2, immagine 1 di 2 SONY ZS-BTG900 Remote Motherboard Replacement: passo 2, immagine 2 di 2
    • Locate the screw behind the battery pack.
    • Use a Phillips size 1 screwdriver to remove the 5/16in screw located inside the battery port.
  3. SONY ZS-BTG900 Remote Motherboard Replacement: passo 3, immagine 1 di 2 SONY ZS-BTG900 Remote Motherboard Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool along the seam on the side of the remote until you hear a click. This means that the plastic tabs holding the remote together are coming loose.
    • Do this until the top half of the remote comes loose.
  4. SONY ZS-BTG900 Remote Motherboard Replacement: passo 4, immagine 1 di 2 SONY ZS-BTG900 Remote Motherboard Replacement: passo 4, immagine 2 di 2
    • Carefully remove the top to reveal the button covers and the remote control board.
  5. SONY ZS-BTG900 Remote Motherboard Replacement: passo 5, immagine 1 di 2 SONY ZS-BTG900 Remote Motherboard Replacement: passo 5, immagine 2 di 2
    • Lift the chip out of the plastic casing to replace it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 428
