Salta al contenuto principale
SONY SRS-X2 Speaker Replacement
Cosa ti serve
  1. SONY SRS-X2 Speaker Replacement, Face Plate: passo 1, immagine 1 di 2 SONY SRS-X2 Speaker Replacement, Face Plate: passo 1, immagine 2 di 2
    • Use the metal spudger to pry the face screen open. Pull away from the device to remove.
  2. SONY SRS-X2 Speaker Replacement: passo 2, immagine 1 di 2 SONY SRS-X2 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove seven, 27 mm long Phillips #1 screws.
    • Remove three, 11mm long Phillips #1 screws.
    • Remove four, 10 mm long Phillips#1 screws.
  3. SONY SRS-X2 Speaker Replacement: passo 3, immagine 1 di 2 SONY SRS-X2 Speaker Replacement: passo 3, immagine 2 di 2
    • Before removing the host plate, face the feet of the speaker to you. The wiring allows for minimal access to the inner components.
    • Use the spudger to remove the speaker host plate. Insert the metal tip in the seam between the host plate and the shell.
    • Be very careful when pulling the speaker host plate (described in the next step) as there are wiring connected to the host plate. This wiring is soldered to the plate and to the shell of the device. The wires are flexible and you can still open the device as shown in the second picture.
    • Center the spudger on the top of the device, this is furthest from the wiring, in wiggling the spudger under the plate, the plate should move up and out of the shell, you can finish lifting the plate away with your fingers.
  4. SONY SRS-X2 Speaker Replacement: passo 4, immagine 1 di 2 SONY SRS-X2 Speaker Replacement: passo 4, immagine 2 di 2
    • Be gentle when using the opening tool, wiggle the opening tool on each side of the socket to be sure the plastic does not snap.
    • Be careful not to damage the wires, pull from the plastic base to unplug.
    • Unplug the power cable connector shown using the plastic opening tool. Wiggle the tool under the lip of the plug, the smaller area and odd angle means lifting up with the plastic tool in the setup shown.
    • Unplug the power connector shown using the plastic opening tool lift from the front of the plug shown and move the opening tool to either side to get it all the way out of the socket.
  5. SONY SRS-X2 Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Be very careful with the iron, it is very hot.
    • Do not hold the soldering iron on the wire too long you could burn through the device.
    • Use the soldering iron to heat the connection shown. Pull the wire once heated to disconnect safely.
  6. SONY SRS-X2 Speaker Replacement: passo 6, immagine 1 di 2 SONY SRS-X2 Speaker Replacement: passo 6, immagine 2 di 2
    • Remove the four, 10 mm Phillips#1 screws from the black pipe. This allows for air to flow through the device to the battery to cool it, but it is in the way of removing the speaker.
    • Once the screws have been taken out just lift the pipe up and away from the device components.
  7. SONY SRS-X2 Speaker Replacement: passo 7, immagine 1 di 1
    • The soldering iron and any connections you melt will be extremely hot, it is a good idea to use heat-safe gloves.
    • Remove the speakers by lifting up and angling the solder ports away from the edge of the speaker housing.
    • Melt the solder from the connection to the speaker, pull the wire to disconnect.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 3-3, Sullivan Fall 2016 Membro di USF Tampa, Team 3-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G3
4 Membri
6 Guide realizzate
5 Commenti
Sony SRS-XB20 Bluetooth speaker
The Sound from the left speaker is normal but the other is much less, about 70% lesser than nomal. To confirm this I had to connect it to my PC, then used the sound settings to seperate the sounds of both speakers and actually noticed that both speakers were working but the output from the right speaker was less than normal. On the other hand when a call comes in or I try to make a call the volume from the right speaker becomes normal.
The microphone no longer works, when I receive a call with the speaker and I talk into the microphone, I am not heard at the other end, also when I activate Siri, and give a command from the speaker Siri appears not hear a thing.
Please what can I do to get this issues resolved because my speaker is still quite new.
Anthony Erhurhu - Replica
The portion of the 27mm screws is incorrect on the left hand top left screw by the left speaker is not a 27mm screw, this just caused me to long screw into the battery terminal
Brannon Reyes - Replica
I need two speaker Sony SRS_x2
D.R ELECTRIC & CONTRACTOR - Replica
This is handy, because I want to add an audio-out jack, so I can geed the output into a P.A.
Now I know how to get into it, should be a piece of cake.
Adam Quantrill - Replica
How can I get spare speaker for srs x2?
Pradeep Kumar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 73
Tutti i Tempi: 3,125
