Introduzione
Safely take apart the speaker and remove the battery for a replacement.
Cosa ti serve
Use the metal spudger to pry the face screen open. Pull away from the device to remove.
Use the spudger to remove the speaker host plate. Insert the metal tip in the seam between the host plate and the shell.
Center the spudger on the top of the device, this is furthest from the wiring, in wiggling the spudger under the plate, the plate should move up and out of the shell, you can finish lifting the plate away with your fingers.
Unplug the power cable connector shown using the plastic opening tool. Wiggle the tool under the lip of the plug, the smaller area and odd angle means lifting up with the plastic tool in the setup shown.
Unplug the power connector shown using the plastic opening tool lift from the front of the plug shown and move the opening tool to either side to get it all the way out of the socket.
Altre 11 persone hanno completato questa guida.
5 Commenti
The top two red in the middle and the bottom two orange in the middle are reversed. Other than that the instructions are good.
THANKS! You are the best!
Can anyone recommend an online store to buy a battery with the attached cable?
2400mAh Battery For Sony Bluetooth Wireless Speaker SRS-X2,9-885-197-08,SF-02
