Salta al contenuto principale
SM Santa Marin hand watch Battery Replacement
Cosa ti serve
  1. SM Santa Marin hand watch Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Take apart the steel strap for the watch by using the round head (SIM) screwdriver. Then pull out the screw.
  2. SM Santa Marin hand watch Battery Replacement: passo 2, immagine 1 di 1
    • Remove four screws from the back cover using the Y000 screwdriver .
  3. SM Santa Marin hand watch Battery Replacement: passo 3, immagine 1 di 1
    • Remove the back cover of the watch using the opening tool.
  4. SM Santa Marin hand watch Battery Replacement: passo 4, immagine 1 di 1
    • Remove the plastic gasket from on top of the battery using the opening tool.
  5. SM Santa Marin hand watch Battery Replacement: passo 5, immagine 1 di 1
    • Loosen the battery bracket from the watch by placing the 1mm flathead screwdriver under and lifting carefully.
  6. SM Santa Marin hand watch Battery Replacement: passo 6, immagine 1 di 2 SM Santa Marin hand watch Battery Replacement: passo 6, immagine 2 di 2
    • Take the old battery out using the plastic opening tool or spudger.
Conclusione
Un commento
It's amazing and also work as a machenic for me
Talha - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 899
