Introduzione
By the end of the guide you will have the ability to replace the motherboard of your device.
Cosa ti serve
Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
The image shows and specify the order of the major components that must be removed before moving on.
Locate the two ribbon cables that will need to be removed.
Using the spudger tool, slide the black clip over the white housing up. This will release the ribbon cable.
Once the ribbon cable is loose, the tweezers should be used to slide the cable out.
Altre 2 persone hanno completato questa guida.
