Introduzione
This guide will walk you through replacing your battery.
Cosa ti serve
Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
Altre 2 persone hanno completato questa guida.
Un commento
Great Instructions! where did you get the battery for the Skytex ?
