Introduzione
Before we can begin working on the internal gear first we must remove the base plate and protective frame. Please refer to our pre-requisite guide before continuing.
Disassembling SKIL 4235 Jigsaw Base plate
Disassembling SKIL 4235 Jigsaw Protective Frame
Parti
Nessuna parte richiesta.
Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
  • Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
Aggiungi Commento
  • Using two hands grip both side of the saw and lift 90 degree as demonstrated.
Aggiungi Commento
  • Identify the screw circled in red and remove with Phillips screwdriver.
Aggiungi Commento
  • Lift base plate up into the air and place off to side. Do not forget to place the removed screw in an area you will easily find it later.
Aggiungi Commento
  • Ensure that the Jigsaw is properly placed and that the blade is away from your body with the screws facing upward.
  • Identify the 10 screws circled for removal. Once all screws have been identified, use your Phillips screwdriver and begin removing them.
Aggiungi Commento
  • Once all screws have been removed, remove the protective frame by gripping it from both sides and lifting it skyward.
  • Be advised
  • You may need to lift with one hand and hold the rest of the saw with the other.
Aggiungi Commento
  • Now placing the frame off to the side you should have a clear view of all the internal working parts. Now we can begin making our repairs.
Aggiungi Commento
  • Be advised:If this is the first time opening up your tool, expect it to be very dirty. It is recommended you use a shamy cloth or wet rag to keep your hands clean.
  • At this point what lies in front of you should be a disassembled version of your SKIL 4235 Jigsaw.
  • Caution: Make sure your device is unplugged.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,037
