Salta al contenuto principale
SIM Card Slot Repair
Cosa ti serve
  1. SIM Card Slot Repair, SIM Card Slot Repair: passo 1, immagine 1 di 3 SIM Card Slot Repair, SIM Card Slot Repair: passo 1, immagine 2 di 3 SIM Card Slot Repair, SIM Card Slot Repair: passo 1, immagine 3 di 3
    • Start by getting your work space set up and clear of clutter.
    • Remove the back of the phone.
    • Remove the battery and set it aside.
  2. SIM Card Slot Repair: passo 2, immagine 1 di 2 SIM Card Slot Repair: passo 2, immagine 2 di 2
    • Remove the six 2.3mm screws with a "T5" Screwdriver.
    • Remove the 2 additional 2.3mm screws from the side opposite the volume and power button.
    • When you open the back of the phone the camera and speaker will be attached to the part that you are removing.
  3. SIM Card Slot Repair: passo 3, immagine 1 di 3 SIM Card Slot Repair: passo 3, immagine 2 di 3 SIM Card Slot Repair: passo 3, immagine 3 di 3
    • Inspect the sim slot to find where the factory solder might be broken.
    • Once found dip the soldering gun in the flux to prevent the solder sticking to the gun.
    • Use the 60/40 lead solder to repair the damaged spot on the sim slot.
    • Do NOT allow the solder to touch any other connections as it could cause the device to short out or no function properly.
Conclusione
Altre 3 persone hanno completato questa guida.
1Commento della guida
I recently purchased a custom built phone which has the best parts of Android with the IMAX 13 camera my SIM tray broke and I can't seem to find anyone that has or knows which kind goes here is there any way you could help me
Bryan S. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 72
Tutti i Tempi: 14,888
