Salta al contenuto principale
SHARP EL-W53XG WriteView Battery Replacement
Cosa ti serve
  1. SHARP EL-W53XG WriteView  Battery Replacement, Battery: passo 1, immagine 1 di 2 SHARP EL-W53XG WriteView  Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
  2. SHARP EL-W53XG WriteView  Battery Replacement: passo 2, immagine 1 di 1
    • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
  3. SHARP EL-W53XG WriteView  Battery Replacement: passo 3, immagine 1 di 2 SHARP EL-W53XG WriteView  Battery Replacement: passo 3, immagine 2 di 2
    • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
    • Remove the battery cover.
    • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
  4. SHARP EL-W53XG WriteView  Battery Replacement: passo 4, immagine 1 di 2 SHARP EL-W53XG WriteView  Battery Replacement: passo 4, immagine 2 di 2
    • Remove the worn-out LR44 battery inside using a spudger.
  5. SHARP EL-W53XG WriteView  Battery Replacement: passo 5, immagine 1 di 1
    • Gently insert the new LR44 battery in the empty battery slot.
  6. SHARP EL-W53XG WriteView  Battery Replacement: passo 6, immagine 1 di 1
    • Place and screw the battery cover on using the Tri-point #000 screwdriver.
    • Tightly screw the battery cover to prevent losing screws.
Conclusione
Faduma Hagi
Membro da: 09/14/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,519
