Salta al contenuto principale
SG 552-1 Commando Barrel Replacement
Cosa ti serve
  1. SG 552-1 Commando Barrel Replacement, Barrel: passo 1, immagine 1 di 2 SG 552-1 Commando Barrel Replacement, Barrel: passo 1, immagine 2 di 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: passo 2, immagine 1 di 2 SG 552-1 Commando Barrel Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: passo 3, immagine 1 di 2 SG 552-1 Commando Barrel Replacement: passo 3, immagine 2 di 2
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: passo 4, immagine 1 di 2 SG 552-1 Commando Barrel Replacement: passo 4, immagine 2 di 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: passo 5, immagine 1 di 2 SG 552-1 Commando Barrel Replacement: passo 5, immagine 2 di 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: passo 6, immagine 1 di 3 SG 552-1 Commando Barrel Replacement: passo 6, immagine 2 di 3 SG 552-1 Commando Barrel Replacement: passo 6, immagine 3 di 3
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: passo 7, immagine 1 di 2 SG 552-1 Commando Barrel Replacement: passo 7, immagine 2 di 2
    • Remove the remaining pieces of on the ends of the barrel.
Conclusione
Laura Schulz
Membro da: 10/05/12
1 Reputazione
1 Guida realizzata
Cal Poly, Team 18-41, Regan Fall 2012 Membro di Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,700
