Introduzione
This guide will cover how to remove the screen of a Samsung ATIV Book 9 Plus.
Parti
Nessuna parte richiesta.
  1. Remove the ten 4.3mm Phillips #00 screws from the bottom cover of the laptop. Remove the ten 4.3mm Phillips #00 screws from the bottom cover of the laptop.
    • Remove the ten 4.3mm Phillips #00 screws from the bottom cover of the laptop.
  2. Press the button to release the bottom cover. Press the button to release the bottom cover. Press the button to release the bottom cover.
    • Press the button to release the bottom cover.
  3. Remove the five 4.3mm Phillips #00 screws from the battery. Remove the five 4.3mm Phillips #00 screws from the battery.
    • Remove the five 4.3mm Phillips #00 screws from the battery.
  4. Lift the battery with both hands and remove. Lift the battery with both hands and remove.
    • Lift the battery with both hands and remove.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Disconnect the display cable from the motherboard. Disconnect the display cable from the motherboard. Disconnect the display cable from the motherboard.
    • Disconnect the display cable from the motherboard.
  7. Disconnect the black and white antenna cables from the Wi-Fi card. Disconnect the black and white antenna cables from the Wi-Fi card.
    • Disconnect the black and white antenna cables from the Wi-Fi card.
  8. Remove the five 4mm Phillips #00 screws from the motherboard retaining brackets. Remove the five 4mm Phillips #00 screws from the motherboard retaining brackets.
    • Remove the five 4mm Phillips #00 screws from the motherboard retaining brackets.
  9. Remove the eight silver 4.2mm Phillips #00 screws from the corner. Remove the eight silver 4.2mm Phillips #00 screws from the corner.
    • Remove the eight silver 4.2mm Phillips #00 screws from the corner.
  10. Pry up the metal hinges from the laptop. Pry up the metal hinges from the laptop. Pry up the metal hinges from the laptop.
    • Pry up the metal hinges from the laptop.
  11. Place the screen on its back side and hold the battery-side of the laptop. In an upward motion, remove the back set off and set it aside. Place the screen on its back side and hold the battery-side of the laptop. In an upward motion, remove the back set off and set it aside. Place the screen on its back side and hold the battery-side of the laptop. In an upward motion, remove the back set off and set it aside.
    • Place the screen on its back side and hold the battery-side of the laptop. In an upward motion, remove the back set off and set it aside.
Conclusione
Sean Kim
Membro da: 12/04/2018
616 Reputazione
4 Guide realizzate
UW Tacoma, Team S1-G2, Liner Spring 2018 Membro di UW Tacoma, Team S1-G2, Liner Spring 2018
UWT-LINER-S18S1G2
5 Membri
4 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 125
