Introduzione
Has the motor in your Ryobi VC120 vacuum reached the end of its life? Try replacing it with this guide!
Cosa ti serve
Pull the black nose off of the body of the vacuum, by pushing in the orange button closest to the nose.
Using a Philips head screwdriver, remove the four screws located on the side panel of the vacuum.
4x 19.1mm
1x 14.3mm
Once the screws are removed, you should be able to separate the side panel from the rest of the device.
Altre 3 persone hanno completato questa guida.
