Salta al contenuto principale
Ryobi VC120 Motor Replacement
Cosa ti serve
  1. Ryobi VC120 Motor Replacement, Filter: passo 1, immagine 1 di 1
    • Pull the black nose off of the body of the vacuum, by pushing in the orange button closest to the nose.
  2. Ryobi VC120 Motor Replacement: passo 2, immagine 1 di 2 Ryobi VC120 Motor Replacement: passo 2, immagine 2 di 2
    • Grab the filter with two fingers and slide it out.
  3. Ryobi VC120 Motor Replacement, Motor: passo 3, immagine 1 di 2 Ryobi VC120 Motor Replacement, Motor: passo 3, immagine 2 di 2
    • Using a Philips head screwdriver, remove the four screws located on the side panel of the vacuum.
    • There are two types of screws on this device. You may want to use a magnetic screw pad to organize your screws to be sure they return to their designated holes.
    • 4x 19.1mm
    • 1x 14.3mm
    • Once the screws are removed, you should be able to separate the side panel from the rest of the device.
  4. Ryobi VC120 Motor Replacement: passo 4, immagine 1 di 3 Ryobi VC120 Motor Replacement: passo 4, immagine 2 di 3 Ryobi VC120 Motor Replacement: passo 4, immagine 3 di 3
    • Pull your motor out, and remove the black and red cables from the motor by hand.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team 2-4, Baechle Fall 2015 Membro di IUPUI, Team 2-4, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 795
