Salta al contenuto principale
Ryobi RS290G Motor Replacement
Cosa ti serve
  1. Ryobi RS290G Motor Replacement, Top Cap: passo 1, immagine 1 di 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Motor Replacement: passo 2, immagine 1 di 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Motor Replacement: passo 3, immagine 1 di 1
    • Remove the top cap.
  4. Ryobi RS290G Motor Replacement, Switch Trigger: passo 4, immagine 1 di 1
    • Remove the switch trigger.
  5. Ryobi RS290G Motor Replacement, Motor: passo 5, immagine 1 di 1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  6. Ryobi RS290G Motor Replacement: passo 6, immagine 1 di 1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  7. Ryobi RS290G Motor Replacement: passo 7, immagine 1 di 2 Ryobi RS290G Motor Replacement: passo 7, immagine 2 di 2
    • Slide the power switch out of the housing assembly.
  8. Ryobi RS290G Motor Replacement: passo 8, immagine 1 di 1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Motor Replacement: passo 9, immagine 1 di 2 Ryobi RS290G Motor Replacement: passo 9, immagine 2 di 2
    • Slide off the disconnect terminal for the switch (red lead) from the power switch using the flat end of a spudger.
  10. Ryobi RS290G Motor Replacement: passo 10, immagine 1 di 2 Ryobi RS290G Motor Replacement: passo 10, immagine 2 di 2
    • Slide out the brush assembly with the black lead from the inner housing assembly.
  11. Ryobi RS290G Motor Replacement: passo 11, immagine 1 di 1
    • Slide off the disconnect terminal for the brush assembly (black lead) from the brush assembly.
    • You may need an ESD-safe flat edge tool, such as a spudger, to help slide off the disconnect terminal. Be careful not to damage the pieces or yourself.
  12. Ryobi RS290G Motor Replacement: passo 12, immagine 1 di 1
    • Remove the armature assembly, with the motor, out of the inner housing assembly.
  13. Ryobi RS290G Motor Replacement: passo 13, immagine 1 di 3 Ryobi RS290G Motor Replacement: passo 13, immagine 2 di 3 Ryobi RS290G Motor Replacement: passo 13, immagine 3 di 3
    • Replace the motor (also known as field assembly).
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,028
