Salta al contenuto principale
Ryobi RS290G Brush Assembly Replacement
Cosa ti serve
  1. Ryobi RS290G Brush Assembly Replacement, Top Cap: passo 1, immagine 1 di 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Brush Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Brush Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the top cap.
  4. Ryobi RS290G Brush Assembly Replacement, Switch Trigger: passo 4, immagine 1 di 1
    • Remove the switch trigger.
  5. Ryobi RS290G Brush Assembly Replacement, Brush Assembly: passo 5, immagine 1 di 2 Ryobi RS290G Brush Assembly Replacement, Brush Assembly: passo 5, immagine 2 di 2
    • Slide the power switch out of the housing assembly by carefully gripping the power switch and slide upward from the base.
  6. Ryobi RS290G Brush Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  7. Ryobi RS290G Brush Assembly Replacement: passo 7, immagine 1 di 1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  8. Ryobi RS290G Brush Assembly Replacement: passo 8, immagine 1 di 1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Brush Assembly Replacement: passo 9, immagine 1 di 2 Ryobi RS290G Brush Assembly Replacement: passo 9, immagine 2 di 2
    • Slide out both brush assemblies from the inner housing assembly.
  10. Ryobi RS290G Brush Assembly Replacement: passo 10, immagine 1 di 1
    • Slide off the disconnect terminal for the brush assembly (white lead).
  11. Ryobi RS290G Brush Assembly Replacement: passo 11, immagine 1 di 1
    • Slide off the disconnect terminal for the brush assembly (black lead).
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 20
Tutti i Tempi: 843
