Introduzione
If your Ryobi RS290G bearing assembly is loose or causing traction pad issues, this guide will show you how to successfully replace the bearing assembly.
Cosa ti serve
Using a TR20 Torx security screwdriver, remove the four 6mm screws.
Quasi finito!
To reassemble your device, follow these instructions in reverse order. Make sure to tighten down properly to avoid loose or traction pad issues.
Conclusione
