Salta al contenuto principale
Ryobi RJ1861V Motor Housing Replacement
Cosa ti serve
  1. Ryobi RJ1861V Motor Housing Replacement, Trigger Assembly: passo 1, immagine 1 di 1
    • Use a Torx T20 screwdriver to remove the nine 16.5 mm screws around the trigger assembly.
  2. Ryobi RJ1861V Motor Housing Replacement: passo 2, immagine 1 di 2 Ryobi RJ1861V Motor Housing Replacement: passo 2, immagine 2 di 2
    • Use a Torx T20 screwdriver to remove the two 16.5 mm screws near the trigger.
  3. Ryobi RJ1861V Motor Housing Replacement, Motor Housing: passo 3, immagine 1 di 1
    • Use a Torx T20 bit or screwdriver to remove the six 19 mm screws securing the gear case cover.
  4. Ryobi RJ1861V Motor Housing Replacement: passo 4, immagine 1 di 2 Ryobi RJ1861V Motor Housing Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #2 bit or screwdriver to remove the four 37 mm screws from the top and the bottom of the gear case.
    • Once these 4 screws are removed, you have access to the motor assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 144
