Introduzione
If the shell of your Ryobi P501G is damaged or compromised, you might want to think about replacing it. A damaged shell might be the result of wear and tear, or overuse. The opening up is not too complex and does not require a lot of experience. You will need the indicated screwdrivers to accomplish the task. There are no warnings or potential hazards when replacing this part.
Cosa ti serve
Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
Remove the three screws on the inside base of the metal casing of the blade.
Pull the metal blade casing off of the Ryobi P501G body.
