Salta al contenuto principale
Ryobi P501G Shell Replacement
Cosa ti serve
  1. Ryobi P501G Shell Replacement, Blade: passo 1, immagine 1 di 1
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: passo 2, immagine 1 di 2 Ryobi P501G Shell Replacement: passo 2, immagine 2 di 2
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: passo 3, immagine 1 di 3 Ryobi P501G Shell Replacement: passo 3, immagine 2 di 3 Ryobi P501G Shell Replacement: passo 3, immagine 3 di 3
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: passo 4, immagine 1 di 1
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: passo 5, immagine 1 di 3 Ryobi P501G Shell Replacement, Shell: passo 5, immagine 2 di 3 Ryobi P501G Shell Replacement, Shell: passo 5, immagine 3 di 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: passo 6, immagine 1 di 3 Ryobi P501G Shell Replacement: passo 6, immagine 2 di 3 Ryobi P501G Shell Replacement: passo 6, immagine 3 di 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
Conclusione
Eeshan Mishra
Membro da: 01/24/19
424 Reputazione
4 Guide realizzate
Cal Poly, Team S1-G2, Maness Spring 2019 Membro di Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 330
