Salta al contenuto principale
Ryobi P235 Direction of Rotation Selector Replacement
Cosa ti serve
  1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: passo 1, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement, Battery: passo 1, immagine 2 di 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Direction of Rotation Selector Replacement: passo 2, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 2, immagine 2 di 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 3, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 3, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Direction of Rotation Selector Replacement: passo 4, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 4, immagine 2 di 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Direction of Rotation Selector Replacement: passo 5, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 5, immagine 2 di 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Direction of Rotation Selector Replacement: passo 6, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 6, immagine 2 di 2
    • Lift the internal components out of the housing.
  7. Ryobi P235 Direction of Rotation Selector Replacement: passo 7, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 7, immagine 2 di 2
    • Remove the gray plastic forward/reverse selector.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 873
