Introduzione
This guide covers the removal process of the outer case. The process does not require removing any of the internal electronics; however it is recommended that the battery is removed in order to reduce the risk of shock. The screws in the case are standard Torx T10 screws. It is advisable to have some place safe to keep all of the screws so that the case can be properly secured during reassembly.
Cosa ti serve
Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
