Salta al contenuto principale
Ryobi P202 Magnetic Tray Replacement
Cosa ti serve
  1. Ryobi P202 Magnetic Tray Replacement, Battery: passo 1, immagine 1 di 3 Ryobi P202 Magnetic Tray Replacement, Battery: passo 1, immagine 2 di 3 Ryobi P202 Magnetic Tray Replacement, Battery: passo 1, immagine 3 di 3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Magnetic Tray Replacement, Right Side Case: passo 2, immagine 1 di 2 Ryobi P202 Magnetic Tray Replacement, Right Side Case: passo 2, immagine 2 di 2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Magnetic Tray Replacement: passo 3, immagine 1 di 2 Ryobi P202 Magnetic Tray Replacement: passo 3, immagine 2 di 2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Magnetic Tray Replacement, Magnetic Tray: passo 4, immagine 1 di 2 Ryobi P202 Magnetic Tray Replacement, Magnetic Tray: passo 4, immagine 2 di 2
    • Gently lift the magnetic tray from the bottom of the drill body.
    • The magnet is Part #: 303001015
Conclusione
Cal Poly, Team 17-6, Forte Spring 2015 Membro di Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 394
