Salta al contenuto principale
Ryobi D620H Mode Selector Switch Replacement
Cosa ti serve
  1. Ryobi D620H Mode Selector Switch Replacement, Right Side Case: passo 1, immagine 1 di 1
    • All nine 16mm long Torx20 screws (Circled in red).
    • Turn the screwdriver counterclockwise to loosen the screws.
    • Remove all nine screws completely.
    • Place in parts tray (Optional)
  2. Ryobi D620H Mode Selector Switch Replacement: passo 2, immagine 1 di 2 Ryobi D620H Mode Selector Switch Replacement: passo 2, immagine 2 di 2
    • Pry the right side of the case off to expose the internal components.
  3. Ryobi D620H Mode Selector Switch Replacement, Mode Selector Switch: passo 3, immagine 1 di 1
    • The mode selector switch (Circled in red) once the right side case is removed.
    • Before disassembling, the mode shift button is visible on the top of the case.
  4. Ryobi D620H Mode Selector Switch Replacement: passo 4, immagine 1 di 3 Ryobi D620H Mode Selector Switch Replacement: passo 4, immagine 2 di 3 Ryobi D620H Mode Selector Switch Replacement: passo 4, immagine 3 di 3
    • Push the mode selector switch up (away from the work surface) to dislodge it.
    • Lift the mode selector switch out of its slot.
Conclusione
To reassemble your device, place the mode shift button in the slot it was removed from at a slight angle and straighten it out as you push it into place.
Congratulations, you have replaced the mode shift button on your Ryobi hammer drill!
UMass Dartmouth, Team 1-2, Petersen Fall 2023 Membro di UMass Dartmouth, Team 1-2, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 79
