Introduzione
Before you start
Due to the stress being applied to the chuck over time, the chuck can become difficult to take off by hand. If this situation happens a screwdriver that is big enough can usually do the job. Working with an impact tool can be very helpful, but you can easily damage the screw that you are trying to remove if you don't do it properly.
Safety:
For your safety, ensure the Ryobi D620H Hammer Drill is not connected to any power source before you perform any repairs.
Cosa ti serve
Loosen the chuck all the way (or at least enough to get a Phillips #3 screwdriver in the jaws.)
Once the jaws of the chuck are open remove the single Phillips #3 screw at the bottom of the chuck while holding the chuck with the chuck key.
Use a pry tool to remove the old chuck.
