Salta al contenuto principale
Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement
Cosa ti serve
  1. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: passo 1, immagine 1 di 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: passo 1, immagine 2 di 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: passo 1, immagine 3 di 3
    • Detach the battery unit from the drill body and pull the battery outwards.
    • If the battery doesn't disconnect easily, gently wiggle the battery back and forth until it comes out.
  2. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Housing Assembly: passo 2, immagine 1 di 1
    • Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
  3. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: passo 3, immagine 1 di 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: passo 3, immagine 2 di 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: passo 3, immagine 3 di 3
    • Grab the sides of the housing and pull straight up until the housing pulls away revealing the inside assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 137
