Salta al contenuto principale
Introduzione
Vacuum does not power on even after the battery has been replaced? The motherboard may be defective. Follow this guide on how to change it for a new one!
Ricambi
Nessuna parte specificata.
  1. Flip the vacuum over so that the wheels are facing you. Use a Phillips #1 screwdriver to remove the four 10mm screws that surround the battery cover.
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10mm screws that surround the battery cover.
  2. Lift up the battery cover to reveal the battery.
    • Lift up the battery cover to reveal the battery.
    • Remove the battery.
  3. Remove the eight 10 mm Phillips #1 screws. Remove the eight 10 mm Phillips #1 screws. Remove the eight 10 mm Phillips #1 screws.
    • Remove the eight 10 mm Phillips #1 screws.
  4. Hold the front bumper and pull it off. It requires a lot of force to pull the bumper off. It requires a lot of force to pull the bumper off.
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. Pry off the back bumper by going around the entire top of the bumper with the metal spudger. Pry off the back bumper by going around the entire top of the bumper with the metal spudger. Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. To access the motherboard entirely, lift the top portion of the vacuum off. To access the motherboard entirely, lift the top portion of the vacuum off. To access the motherboard entirely, lift the top portion of the vacuum off.
    • To access the motherboard entirely, lift the top portion of the vacuum off.
  7. Locate the four main 10mm screws on the underside of the motherboard.
    • Locate the four main 10mm screws on the underside of the motherboard.
  8. Use a Phillip's #1 screwdriver to unscrew and remove the four 10 mm screws. Use a Phillip's #1 screwdriver to unscrew and remove the four 10 mm screws.
    • Use a Phillip's #1 screwdriver to unscrew and remove the four 10 mm screws.
  9. Pinch the two tabs together, shown here, to loosen the motherboard out of the vacuum. Lightly pull on the USB connector shown to lift the motherboard out. Lightly pull on the USB connector shown to lift the motherboard out.
    • Pinch the two tabs together, shown here, to loosen the motherboard out of the vacuum.
    • Lightly pull on the USB connector shown to lift the motherboard out.
Conclusione
Jessica Alimonti
Membro da: 17/02/2017
138 Reputazione
1 Guida realizzata
USFT-Lacy-S17S005G2 Membro di USFT-Lacy-S17S005G2
Meetup
4 Membri
5 Guide realizzate
This was GREAT.... Lots of pics :-)
I was able to pull the mother board without much trouble. Mostly scared of breaking the connections.
NOW???? Where do I buy the darn thing?
Please respond,
Robert
Robert Kilgore - Replica
Unfortunately, it looks like Moneual had some fraud issues and went under in 2014. It may be difficult to get your hands on replacement parts for the Rydis H68 Pro. =[
Richard Suovanen -
where are the internal batteries CR2032 ?? I have heard that problems maybe due to internal batteries and not motherboard. Unable to get top off.
Do you know how to do a factory reset ? thank you. N. Tribley Oct. 23
naomi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 968
