Salta al contenuto principale
Introduzione
Is your vacuum bumping into everything? Replacing the bumpers may solve the problem.
Ricambi
Nessuna parte specificata.
  1. Flip the vacuum over so that the wheels are facing you. Use a Phillips #1 screwdriver to remove the four 10mm screws that surround the battery cover.
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10mm screws that surround the battery cover.
  2. Lift up the battery cover to reveal the battery.
    • Lift up the battery cover to reveal the battery.
    • Remove the battery.
  3. Remove the eight 10 mm Phillips #1 screws. Remove the eight 10 mm Phillips #1 screws. Remove the eight 10 mm Phillips #1 screws.
    • Remove the eight 10 mm Phillips #1 screws.
  4. Hold the front bumper and pull it off. It requires a lot of force to pull the bumper off. It requires a lot of force to pull the bumper off.
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. Pry off the back bumper by going around the entire top of the bumper with the metal spudger. Pry off the back bumper by going around the entire top of the bumper with the metal spudger. Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
Conclusione
Joe Balduz
Membro da: 15/02/2017
231 Reputazione
2 Guide realizzate
USFT-Lacy-S17S005G2 Membro di USFT-Lacy-S17S005G2
Meetup
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 323
