Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Rubik's Cube, usa il nostro manuale di assistenza.
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: passo 1, immagine 1 di 3 Rubik's Cube Teardown, Rubik's Cube Teardown: passo 1, immagine 2 di 3 Rubik's Cube Teardown, Rubik's Cube Teardown: passo 1, immagine 3 di 3
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: passo 2, immagine 1 di 2 Rubik's Cube Teardown: passo 2, immagine 2 di 2
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: passo 3, immagine 1 di 2 Rubik's Cube Teardown: passo 3, immagine 2 di 2
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
rab777hp
Membro da: 11/17/09
20.343 Reputazione
3 Guide realizzate
OPEN Membro di OPEN
Community
85 Membri
27 Guide realizzate
6 Commenti
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Replica
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - Replica
my middle peices came out cant fix it
jax - Replica
can someone tell me how to fix it
jax - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 67
Tutti i Tempi: 24,919
