Salta al contenuto principale
Rubber Watch Battery Replacement
Cosa ti serve
  1. Rubber Watch Battery Replacement, Battery: passo 1, immagine 1 di 2 Rubber Watch Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Begin by placing the watch on its backside.
  2. Rubber Watch Battery Replacement: passo 2, immagine 1 di 3 Rubber Watch Battery Replacement: passo 2, immagine 2 di 3 Rubber Watch Battery Replacement: passo 2, immagine 3 di 3
    • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
    • Pull out the white cap and green chip once it is free.
  3. Rubber Watch Battery Replacement: passo 3, immagine 1 di 1
    • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
    • Be careful not to insert the X-Acto knife too downward into the battery.
  4. Rubber Watch Battery Replacement: passo 4, immagine 1 di 3 Rubber Watch Battery Replacement: passo 4, immagine 2 di 3 Rubber Watch Battery Replacement: passo 4, immagine 3 di 3
    • Flip the chip around to the front.
    • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
    • Make sure to hold the knife away from the hands in a safe, stable grip.
    • Remove the cut plastic casing over the battery.
    • The plastic casing should come off like a cap.
  5. Rubber Watch Battery Replacement: passo 5, immagine 1 di 1
    • Gently remove the battery with a spudger or a wooden coffee stick.
    • Using too much force may detach the tab holding the battery and break the watch.
    • Once free, remove the dead battery.
  6. Rubber Watch Battery Replacement: passo 6, immagine 1 di 1
    • Insert the new battery.
    • Place the cut plastic cap casing over the chip and battery.
  7. Rubber Watch Battery Replacement: passo 7, immagine 1 di 3 Rubber Watch Battery Replacement: passo 7, immagine 2 di 3 Rubber Watch Battery Replacement: passo 7, immagine 3 di 3
    • Place the white cap over the green chip.
    • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
    • Turn over the watch and check the power.
Linea Traguardo
Lee
Membro da: 04/28/17
110 Reputazione
1 Guida realizzata
UC Davis, Team S2-G5, Cole Spring 2017 Membro di UC Davis, Team S2-G5, Cole Spring 2017
UCD-COLE-S17S2G5
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 754
